Heater blower motor was working on high speed only. It has now quit blowing altogether. Any ideas?
Sunday, January 17th, 2010 AT 8:16 PM
MECHANIC
The hi speed only indicates a bad blower motor resister. If it has stopped, check to make sure the motor is good. I would replace the resister first, and if that doesn't help, check to see if you are getting power to the motor. If you are, then chances are the motor is bad.
