2002 Dodge Dakota heater fan?
KIGGY
  • 2002 DODGE DAKOTA
  • 6 CYL
  • 130,000 MILES
My low and med fan setting's stopped working and then
my high speed stopped working for the heat in the cab
Sunday, January 11th, 2009 AT 2:23 PM
  • 109,867 POSTS
Hi:
The most common problem is the blower motor resister. It's a cheap part. If you want to be sure, check for power to the motor. If there is no power, replace the resister. If there is power, make sure you have a good ground. If you do, the motor may be bad.
Let me know if this helps.
Tuesday, April 16th, 2019 AT 2:22 PM
