2001 Dodge Dakota cruise control
2001 DODGE DAKOTA
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
KALI08
I recently purchased a 01 dakota and the cruise won't turn or set or do anything. Is there a fuse for this. I checked for a cruise fuse but could not locate one. Is it possibly connected to another fuse.
Thank You
Jan 1, 2009 at 2:53 PM
  • 110,244 POSTS
Hi:
If you have the owner's manual, it should be located there, but chances are it's not a fuse. The CC runs off a speed sensor in the trans and the PCM. Most likely it won't kick any codes, but since most nationally recognized parts stores will scan it for free, you may want to try. Otherwise, you need to take it to a dealer that will have the proper test equipment the check for specific problems.
Jan 1, 2009 at 5:00 PM
