2000 Dodge Dakota Whine in transmission
2000 DODGE DAKOTA
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
METECHCA
I have a very noticable whine in my trans. In all gears but over drive. The shifting is perfect but this whine is there from 1st gear right up until it shifts into od.
the pitch of the whine doesn't change with gear shifiting but rather with speed of drive train.
If i put it in nuetral and shut the engine off to coast, it is still there. when it shifts into od, you can here the shift in the whine and then disappear.
In other words, when the trans shifts into od, the tone of the whine will change with the shift and go away.
Any help would be appreciated.
Oct 3, 2008 at 11:56 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds more like a rear end problem. Dodge/Chrysler/Jeep have alot of problems with carrier bearings going out in their rear ends.If it is a trans problem it should change with shifts, rear ends are turning the same rpm's the entire time, and when in OD, you are cruising and no longer on the throttle so the load changes on the rear end. Plus when shut down a trans noise would most likely go away.
Oct 4, 2008 at 1:15 AM
