2000 Dodge Dakota Speedometer reads about twice the real sp
2000 DODGE DAKOTA
20RDMAG
Electrical problem
2000 Dodge Dakota V8 Two Wheel Drive Manual 120K miles
I just bought this Dakota and I'm trying track down the cause of the speedometer reading about twice the real speed. I have changed the output speed sensor at the transmission but no luck. The speedometer still over reads actual speed.
Dec 9, 2008 at 2:58 PM
MMPRINCE4000
  • 8,548 POSTS
First make sure the VSS is corrrect for this model, manufacturers will sometimes make midyear parts changes.
If correct, then you may have a wiring problem to the PCM or bad PCM or speedometer gauge in the IP.
Dec 10, 2008 at 2:24 AM
