Fuel filter location?
GT302HO
  • 2002 DODGE DAKOTA
  • 4.7L
  • V8
  • 4WD
  • 103 MILES
Where is the fuel filter located and how to change?
Saturday, February 22nd, 2014 AT 7:47 AM
HMAC300
  • 48,601 POSTS
On top of fuel tank it is part of regulator there are three different ones. Here is a diagram below and a guide to help walk you through the repair.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
and
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Saturday, February 22nd, 2014 AT 8:58 AM
BHLOCKEY
  • 1999 DODGE DAKOTA
  • 4 CYL
  • MANUAL
  • 110,000 MILES
My truck ran out of fuel and I cannot get it to start. I have put gas in the gas tank. I cannot locate the fuel filter. The owner manual advises not to push it to start it. Can you advisr me of the location of the fuel filter. Thanks
Sunday, March 31st, 2019 AT 11:40 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Fuel filter is combined with
Regulator and mounted in fuel pump module in fuel tank
RNMEDIC2004
  • 2000 DODGE DAKOTA
Where is the fuel filter for a 2000 Dodge Dakota Sport 4x4 manual transmission?
SERVICE WRITER
  • 9,123 POSTS
Might be wrong, but almost positive that it is part of the fuelpump/sending unit assy. It may also set on top of the assy, and be replaceable. IF it is that one, it may be incorporated into the fuel pressure regulator.
CAVALIER911
  • 2001 DODGE DAKOTA
2001 Dodge Dakota 6 cyl Four Wheel Drive Manual
where is the fuel filter located
MADMIKE1735
  • 951 POSTS
The fuel filter is located inside the tank. The filter is also attached to the fuel pressure regulator. It requires the entire pump assembly to be replaced.
SATURNTECH9
  • 30,869 POSTS
A combination fuel filter and fuel pressure regulator is located on the top of the fuel pump module.
KABOO2908
  • 2000 DODGE DAKOTA
  • 6 CYL
  • 130,000 MILES
How many fuel filters are there and where are they located
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_fuel_filter_2.jpg
My info shows it's part of the fuel pump module.
SHADRACH202
  • 1998 DODGE DAKOTA
  • 6 CYL
  • 100,000 MILES
Where is the fuel filter located?
BLUELIGHTNIN6
  • 16,542 POSTS
Under vehicle, center, below seating area, mounted on top of fuel tank, in fuel pump module
TIMEMILY
  • 1998 DODGE DAKOTA
  • V8
  • 4WD
  • 13,870 MILES
Can you tell us where the fuel filter is located at
ECHARLIE08
  • 1997 DODGE DAKOTA
  • V8
  • 4WD
  • 164,000 MILES
Where is the fuel filter located on my truck. The haynes manual says it is on top of my gas tank. But the part we have doesnt look like the part in the manual and we cant find anything that looks like it. Could there be that part up there or do we not have the right part. Thanks guys
Sunday, March 31st, 2019 AT 11:41 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
You have to drop down the tank
SERVICE WRITER
  • 9,123 POSTS
It's on top of the fuel pump/sending unit module.
The filter is part of the regulator.
https://www.2carpros.com/forum/automotive_pictures/30961_reg_1.jpg
GUY6626
  • DODGE DAKOTA
Where and how do I change my fuel filter on my 2000 dodge dakota club cab. It has a 2.5 L4 motor.
TE1976
  • 6 POSTS
It is in gas tank.
BRUCE HUNT
  • 3,754 POSTS
Fuel pump might be in the tank but nobody should be stupid enough to design a FILTER for the tank. Follow the line from the tank, it will be easy to trace.
IRISHROB
  • 2002 DODGE DAKOTA
  • 6 CYL
  • 4WD
  • 91,700 MILES
I was wondering where the fuel filter is? And if it is easy to fix myself?
