1999 Dodge Dakota Possible spark knock
1999 DODGE DAKOTA
150,000 MILES • V8 • 4WD • AUTOMATIC
BEEF99
  • 152 POSTS
I am hearing a sound that is like a spark knock and I suspect that is what it is but I have had the computer udated for spark knock, vacuum leaks checked under the intake at the plenum, and a complete tune-up. I am at my wits end as to what the problem is and now people are telling me to take it to a dealer to have a proffessional fuel cleaning job. There is also a noise that sounds like it is coming from the lower rear portion of the engine and do not have a clue. I am the third owner and the second owner kind of took care of the truck but not sure how well he did at it. Any ideas would be helpful on how to locate and find the source for the engine noises would be greatly appreciated. These noises are louder than they should be but not loud enough to think the engine is going to fall apart though.
Jul 11, 2009 at 7:26 AM
DOCFIXIT
  • 18,828 POSTS
Does it knock at idle? on acceleration? does it quit when you lift off gas?
Jul 11, 2009 at 7:52 AM
BEEF99
  • 152 POSTS
It only does it under acceleration, not at idle. When I am at a cruizing speed, and step on the gas it sounds like spark knock. It is not extrememly loud and I cannot hear it at higher speeds unless the window is down. The vehicle runs superb and is in great condition. The engine idles smoothly too. It is not the timing chain either.
Jul 11, 2009 at 8:02 AM
DOCFIXIT
  • 18,828 POSTS
Your year engine has a common problem with spark knock on accel. caused by a leaking intake plenum pan gasket. It is internal and only clue to it being problem is knock and a slight rise in oil consumption.
Jul 11, 2009 at 8:17 AM
BEEF99
  • 152 POSTS
And yes, it quits when I take my foot off of the gas, I am pretty good with engines and vehicles and have restored many but this is driving me crazy lol.
Jul 11, 2009 at 8:18 AM
BEEF99
  • 152 POSTS
The plenum has been looked at and tested, there is no oil consumption, the throttle body is clean as a whistle inside and someone at a reputable shop said they disconnected the hoses that go into the plastic part for the air filter assembly from the valve covers, and checked to see what the engine did when they were plugged and so on, and that test checked out too(supposedly for vacuum leaks).
Jul 11, 2009 at 8:22 AM
DOCFIXIT
  • 18,828 POSTS
Check EGR operation should pull off check passage ways clean if needed. If EGR does not recirculate exhaust into combustion chamber then temps rise NoX forms and you get spark knock.
Jul 11, 2009 at 8:34 AM
BEEF99
  • 152 POSTS
Thanks, I haven't heard this one before, I will do that!
Jul 11, 2009 at 8:36 AM
CEMENT HEAD
  • 38 POSTS
it also sounds like a octane ping, which means you need a better grade of fuel. where the new spark plugs put in the same heat range as the ones you took out? Also the gap on the plugs might not be set right.
Jul 20, 2009 at 2:18 PM
BEEF99
  • 152 POSTS
It was a combination of a minor exhaust leak and the EGR that needed to be cleaned. Thank you for the advice but I am usually pretty good with mechanical problems but when you are not familier with a vehicle or have a sound that could be a million things it is easy to overlook something. My truck is not stock and always runs on high octane fuel and never anything under 93 octane. It has hot pluds in it, high voltage coil, a performance chip, and other performance additions and the problem existed since before I obtained the vehicle and continued the same even after all the tune-ups were done and performance parts added.
Jul 20, 2009 at 2:36 PM
