1999 Dodge Dakota Heater Core
JAMES TRUJILLO
  • 1999 DODGE DAKOTA
  • 6 CYL
  • MANUAL
  • 120,000 MILES
Heater will not blow warm air when you put the fan on higher then the low speed. Can smell prestone once in awhile in the cab.
Thursday, January 24th, 2008 AT 9:38 AM
BMRFIXIT
  • 19,053 POSTS
Check coolant level and adjust if needed
check for leaks ( oil and or coolant )
try flushing heater core
also check water pump and its operation
Saturday, January 26th, 2008 AT 8:54 PM
