1999 Dodge Dakota
WHITETAILBULLET2
  • 1999 DODGE DAKOTA
Heater problem
1999 Dodge Dakota 6 cyl Four Wheel Drive Automatic
how do you get heater core out
Thursday, November 4th, 2010 AT 7:15 AM
  • 109,885 POSTS
Here is what I was able to find:
Disconnect the battery negative cable.
Remove the instrument panel from the vehicle.
If equipped with air conditioning, recover the refrigerant.
Disconnect the liquid line refrigerant line fitting from the evaporator inlet tube.
Ram: remove the accumulator.
Dakota, Durango: disconnect the accumulator inlet tube.
Drain the cooling system.
Disconnect the heater hoses from the heater core tubes.
Ram: remove the powertrain control module from the dash panel. Disconnecting wiring is not necessary.
Remove the four nuts from the heater-A/C mounting studs on the engine compartment side of the dash panel.
Remove the nut(s) that secure(s) the heater-A/C housing mounting brace to the stud(s) on the passenger compartment side of the dash board.
Pull the housing rearward far enough for the mounting studs and evaporator condensate drain tube to clear the dash panel holes.
Remove the housing from the vehicle.
Lift the heater core out of the housing.
Installation is the reverse of removal.
NOTE: If you have AC, the system will need evacuated and recharged.
Thursday, November 4th, 2010 AT 7:36 AM
