1998 Dodge Dakota idling
SHARVEY
  • 1998 DODGE DAKOTA
Engine Mechanical problem
1998 Dodge Dakota Two Wheel Drive Automatic 104000 miles
My truck is idling way to high. It will idle on 1 or 2. What can I do for that?
Saturday, February 14th, 2009 AT 10:36 PM
Idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include throttle body gaskets, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft.
Saturday, February 14th, 2009 AT 10:49 PM
