[quote:c0277a13af="poormnsdvd"]Electrical problem
1997 Dodge Dakota 4 cyl Two Wheel Drive Manual 140000 miles
97 dodge dakota 4 cyl
was driving down the road truck started chugging like it was a clogged fuel filter.
or ice in line pulled into gas station to put in dry gas and truck died noticed fuel gauge said it was empty so i put in 20 dollars still gas gauge sai empty. cranks over no start and i dont hear the fuel pump engage.
i guess my question is could it be a broke wire or if the fuel pumps goes bad will the gas gauge also go bad?
and can i some how hot wire the pump to check for operation and trouble shooting?[/quote:c0277a13af]
ok pulled gas tank and fuel pump out jumpered fuel pump and runs when i do ?
found 2 fuses for fuel pump one checks good simple two prong check
the other however is a 6 prong how would i check that? and if that is bad would that cause both the fuel pump and the gas gauge not to work ?
Oct 1, 2019 at 8:57 AM
(Merged)
