1998 Dodge Dakota diagnostic code
BANNON JONES
Electrical problem
1998 Dodge Dakota 6 cyl Four Wheel Drive Automatic
When reading the diagnostic code that exists, what does over-charging mean? And is it fairly cheap to fix?
Feb 26, 2010 at 8:31 AM
  • 110,248 POSTS
It sounds like the alternator is overcharging the system. It could be a bad voltage regulator. You need to check with the local parts store to confirm if the alternator on a 98 is built into the alt itself. I can't remember the exact years, but I know the early 90's were regulated through the computer which ment when the voltage regulator was bad, you had to replace the computer.
Feb 27, 2010 at 1:42 PM
