1998 Dodge Dakota Clunking while driving
105,000 MILES • V8 • 4WD • AUTOMATIC
SREDNAS
I just replaced tires that had uneven wear because i found out as i was having an alignment done that my ball joints were bad.
There was sqeaking in the suspension. I then replaced upper and lower ball joints and test drove. I now hear a clunking sound that was not present before. I almost sounds like rubbing, i checked for clearance and didn't see anything.
Could replacing the ball joints now expose bad CV jointss too? I looked at the drive axle when i had the steering knuckle off and they seemed fine. Any ideas?
Nov 8, 2010 at 2:17 AM
  • 110,248 POSTS
CV joints usually click. As far as the noise you hear now, is it only over bumps?
Nov 8, 2010 at 5:00 AM
SREDNAS
It does happen when i go over bumps. I first noticed it going up and down a hill during the test drive. It doesn't happen on tight turns only; wide turns too and driving straight. I took a passenger on the 2nd test drive and it didnt happen as much.
The only other thing i can think of is maybe i didn't torque the castle nuts tight enough?
The only thing that was different from textbook was the upper ball joints were factory rivited vs the after market parts which are bolted.
Nov 8, 2010 at 6:49 AM
  • 110,248 POSTS
I would recommend rechecking the bolts to make sure everything is tight. It sounds like a simple issue.
Nov 8, 2010 at 11:06 PM
