Noise
CHINSY2000
  • 6 POSTS
I have a 2002 dodge dakota 4.7L V8 it is making a clunking noise when driving only when leting off the gas and goes away when pushing the gas. Thanks Jeff Loucks
Nov 24, 2007 at 2:42 AM
MAXVOLT
  • 7 POSTS
Chinsy,
A clunking noise COULD be the beginnings of bad universal joints on your drive shaft. You should not only hear this clunk when you come off the accelerator, but also when you put it into gear from park (Drive or Reverse). Thats the best guess I could give you. Tou should have two universal joints (also called U-joints), one on each end of the driveshaft, change them both.
I hope this works out for you
Dec 1, 2007 at 3:07 AM
