1997 Dodge Dakota Leaking antifreeze
104,000 MILES • V8 • 2WD • AUTOMATIC
SCOTT DAVISON
I noticed an antifreeze smell when I got home from work yesterday. I popped the hood open and there was antifreeze all over the front of the engine. I'm assuming that the fan and regular air movement from the drive home spread the antifreeze everywhere. i borrowed a pressure tester and hooked it up. I can't spot the leak, but the bottom of the engine (in front), the crossmember and the fan shroud seem to be especially heavily covered with antifreeze. I will try again tomorrow in the daylight hours and with the truck up on ramps so I will have a better view, but do you have any ideas on what my problem could be? Thank you.
Feb 23, 2009 at 4:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Did temp. gauge ever go to hot? Radiator may have boiled over or a radiator hose may have busted or came loose.
Feb 23, 2009 at 5:52 PM
SCOTT DAVISON
No, the temp guage never has gone over 180-185, and it has never overheated. Also, the radiator was still full and the overflow was down just a little.
Feb 24, 2009 at 1:04 AM
