1996 Dodge Dakota Will not start
RON PADEN
  • 1996 DODGE DAKOTA
  • 4 CYL
  • MANUAL
  • 87,000 MILES
I have no spark from the ignition coil. I replaced the coil to find no difference. I can measure 12 volts supplied to the coil for a few seconds when the key is first turned on. That voltage then goes to zero and no voltage is present when I turn the engine over. I looked for blown fuses and found none. What else should I be looking for?
Wednesday, April 22nd, 2009 AT 2:35 PM
BMRFIXIT
  • 19,053 POSTS
Crank position sensor turn key on do you have check engine light on
you should crank to start engine check engine light should go out if not 1st check and replace crank sensor
let me know
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Friday, April 24th, 2009 AT 5:50 AM
