1995 Dodge Dakota Check Engine Light
SOULSARGE007
  • 1995 DODGE DAKOTA
  • 6 CYL
  • MANUAL
  • 154,444 MILES
I just brought this truck used from someone. The truck runs well except for a little shaking when hitting the brakes. But after driving around for a while the check engine light comes on and I cannot figure out why.
Tuesday, February 2nd, 2010 AT 11:22 AM
JDL
  • 16,098 POSTS
Welcome to the forumm, as far as the brakes, check the brake pads. Safely raise and support the vehicle, shake the tires, up and down, side to side, in and out, roll where applicable, see if you feel--hear--see any loosness or sounds.
You should be able to check mil codes. You turn the key just till the dash lites come on, no further. Cycle the key, on--off, on--off, on, then the mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
Tuesday, February 2nd, 2010 AT 11:37 AM
