1995 Dodge Dakota Coolant Sensor Code
D BROWN
I have a 1995 Dodge Dakota, 4X2, AT, 3.9 L V6 76,500 miles. I have a check engine light that come on after I have driven apporx 20 miles, the code is for a coolant sensor. Sensor has been replaced. The check engine light continues to come on after approx 20 miles have been driven. The sensor has been rechecked and is working properly. When the check engine light comes on the engine idles rough or stalls while in park, idles in drive rough. Any suggestion on where to look or what to check to correct this problem. Thanks
Doug
Nov 18, 2007 at 12:36 AM
BMRFIXIT
  • 19,053 POSTS
[quote:60f7a09ac4="D Brown"]I have a 1995 Dodge Dakota, 4X2, AT, 3.9 L V6 76,500 miles. I have a check engine light that come on after I have driven apporx 20 miles, the code is for a coolant sensor. Sensor has been replaced. The check engine light continues to come on after approx 20 miles have been driven. The sensor has been rechecked and is working properly. When the check engine light comes on the engine idles rough or stalls while in park, idles in drive rough. Any suggestion on where to look or what to check to correct this problem. Thanks
Doug[/quote:60f7a09ac4]
been throw that
u have to look for a bad ground or wire in the harness
look behind the engine by the firewall
Nov 18, 2007 at 12:47 AM
Suggested Repair
Inspect the coolant sensor circuit for a bad ground or damaged wire in the harness, especially behind the engine near the firewall.
Conversation Summary
A 1995 Dodge Dakota sets a coolant sensor code and the check engine light after about 20 miles, even though the sensor was replaced and rechecked. When the light comes on, the engine idles roughly or stalls in park and idles roughly in drive. The expert recommends checking for a bad ground or wiring problem in the harness behind the engine by the firewall.
