It starts and runs great until it's warmed up then it dies/ stalls when idle at a stoplight, etc.
Friday, April 16th, 2010 AT 1:08 PM
MECHANIC
HAs the check engine light come on? Have you checked for vacuum leaks?
SPONSORED LINKS
Friday, April 16th, 2010 AT 9:51 PM
BENFORBING
MEMBER
No. But have cleaned throttle body and still have no idea. It would make more sense to stall when cold but not when warmed up.
Saturday, April 17th, 2010 AT 11:26 AM
MECHANIC
Actually, in the old days, yes. Today, there is a temp sesor that tells the computer how rich to make the fuel mixture based on outside temps and coolant temp. Have you checked the EGR valve to make sure it is working? Also, have you checked for trouble codes?
Sunday, April 18th, 2010 AT 3:00 PM
BENFORBING
MEMBER
No. But will do Joe actually forgot about the EGR valve. Thanks man! And will let ya know. :-)
Monday, April 19th, 2010 AT 9:37 AM
MECHANIC
Glad to help. I just hope it does. Make sure there is no carbon build up in the intake as well as the EGR. Also, check vacuum hoses to the EGR. I have seen them plugged too.
