1994 Dodge Dakota 1994 Dakota stalls when stopping
HCSVADER
  • 1994 DODGE DAKOTA
  • 6 CYL
  • 264,000 MILES
94 dakota stalls when comming to a stop. Starts again immediatly but stalls again the next time I stop. It also stalls when shifted into neutral at stops.
previous owner reported this problem but didn't know the cause. Came with a cracked exhuast manifold which I repaired. After that the truck ran much better and only started stalling again now that the weather is gettng colder. I bought the truk in the spring. Also the fuel pump was just replaced.
Friday, November 21st, 2008 AT 9:58 PM
  • 109,951 POSTS
Hi:
First, is the check engine light coming on? Regardless, I want you to check for codes. From the off position, cycle the key from of to run 3 times. The third time let it stay in the run position. If the check engine light begins to flash, count the number of flashes it does. When changing from one number to the next, there will be a slight delay then it will start again.
Let me know what you find.
Wednesday, December 3rd, 2008 AT 10:49 PM
