Transmission problem
1993 Dodge Dakota V8 Two Wheel Drive Automatic 239K miles
I'm going to replace the front pump seal in my transmission. I've got everything taken loose and a jack under the trans. pan. I am having trouble getting the trans. dipstick out of the tran. can you give me any advice on getting it out without damaging it? Also, can you give me advice on removing trans. replacing front seal and replacing tran. I am also replacing the rear main engine seal while I have the trans. out. Any advice on replacing that would be greately appreciated.
Thank you,
David
Thank you,
David
Jan 24, 2010 at 4:28 PM
