where is it on the eng. flashes 35455
when I do the key check
Nov 9, 2009 at 3:02 PM
CH112063
✓Experienced Mechanic
I'm not sure about the 3 but 54 means you may have a truck that is shutting off on you, or has failed because of a broken timing chain. 54 was distributor pick-up, no signal, this is the computers cam signal. if you have a 1 and a 3 meaning 13, this is MAP sensor, no signal, starts and stalls. Hope this helps.
