1992 Dodge Dakota coeds ??????
EDDIESTRUCK
Computer problem
1992 Dodge Dakota Two Wheel Drive Automatic 153000 miles
I have 35455 what is it ???????
this what flashes
Nov 9, 2009 at 4:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Code 54 : No Sync Pick-Up Signal
No fuel sync signal detected during engine rotation
Code 55 : Completion of Fault Code Display by Check Engine light
This code simply indicates end of fault codes stored by check engine lamp.
No code 03 was found in the dealer's repair guide. You may want to repeat the steps of retrieving the codes to ensure you have the correct codes.
Nov 9, 2009 at 5:25 AM
