My instrument cluster isn't working right?
124,500 MILES • V8 • 4WD • AUTOMATIC
KNOTE72
I have a 1991 dodge dakota 4x4 with 124,500 miles on it. My instrument cluster isn't working right. The gas gauge, temp. gauge, battery gauge, and oil gauge work, but my odometer and tripometer don't. Plus, my speedometer is only accurate above 55 mph. Any slower and the needle bounces. What do you think is wrong?
Feb 26, 2009 at 7:42 PM
  • 110,245 POSTS
First, make sure the cable from the speedo to the trans is tight and hasn't come loose. Next, disconnect it from the rear of the speedo to make sure is isn't broken inside the outter shell. If it's broken inside, you will be able to spin it with your fingers. If everything is good with the cable, I hate to say it but the speedo most likely needs replaced.
Let me know what you find.
joe
Feb 27, 2009 at 10:50 AM
KNOTE72
thanks, now i know what to look for.
Feb 27, 2009 at 1:54 PM
