1991 Dodge Dakota
JUS10ANDRU
  • 1991 DODGE DAKOTA
Air Conditioning problem
1991 Dodge Dakota V8 Two Wheel Drive Automatic
My A/C works when im driving but when icome to a stop, it stops blowing. What is the problem?
Friday, September 4th, 2009 AT 8:33 PM
  • 109,885 POSTS
When you say it stops, do you mean the blower stops or it no longer blows cold air?
Wednesday, September 9th, 2009 AT 10:08 PM
JUS10ANDRU
  • 5 POSTS
The blower stops. It blows no air at all
Friday, September 11th, 2009 AT 8:45 AM
  • 109,885 POSTS
Have you checked for power to the motor when this happens? Also, make sure the blower motor resister plug is in good condition.
Friday, September 11th, 2009 AT 10:35 AM
JUS10ANDRU
  • 5 POSTS
And to the non mechanics, where is that?
Friday, September 11th, 2009 AT 7:22 PM
  • 109,885 POSTS
What I mean is have you checked to see if the blower motor is getting power when it isn't working. There could be a short, loose connection to the motor, a bad or shorted resister.
I realize this may be confusing, but the blower motor is under the dash on the passanger side. It isn't real easy to get to. When the motor stops, I need you to check the electrical connector to see if there is power to it. You can use a test light or volt meter. If there is power and the motor refuses to run, it is most likely bad. If there is no power, then we need to check what is called a blower motor resister. It is easy to get to.
Let me know if this makes sense to you. It's hard to explain via the internet. If I was there I could show you in about 10 minutes.
Friday, September 11th, 2009 AT 9:50 PM
JUS10ANDRU
  • 5 POSTS
Ok. Would I have to go under the hood or through the dash? What would u prefer?
Saturday, September 12th, 2009 AT 12:40 AM
  • 109,885 POSTS
Okay. You need to check t see if the power is making it to it's final point, the blower motor. It is under the dash on the passanger side (behind the glove box). You will need to remove the glove box, then you will see the HVAC vent works. The blower motor is behind there. If I remember correctly, you also need to remove the bottom of the dash. It is screwed into place.
Saturday, September 12th, 2009 AT 11:37 AM
JUS10ANDRU
  • 5 POSTS
Alright. Ill check it out and get back to you. I appreciate your time and advice
Saturday, September 12th, 2009 AT 1:25 PM
