Hi Smooph,
Thank you for the donation.
Here are a list of possible causes.
Aerated fluid.
Defective clutch or servo.
Governor support seal rings broken or worn.
Improper fluid level.
Incorrect shift linkage or cable adjustment.
Incorrect throttle linkage adjustment or binding linkage.
Restricted filter assembly.
Check the fluid condition and level first. If fluid is dark, the filter would have to be replaced as well.
SPONSORED LINKS
Monday, May 4th, 2009 AT 3:33 PM
