2003 Dodge Dakota RPM fluctulation
2003 DODGE DAKOTA
92,544 MILES • V8 • 2WD • AUTOMATIC
JACKK121
  • 9 POSTS
RPM fluctulate. While driving my RPM will fluctuale but I lose no engine speed. It does this at any speed and if I hit a bump in road the RPM will flucuate. Dodge dealer claim If was cause by my fuel injetors which I had cleaned and the problems is still occuring. Please help with this problems. Thanks
Feb 15, 2010 at 6:17 AM
  • 110,244 POSTS
This can be tough if the check engine light hasn't come on. Has it? Also, have you checked fuel pump pressure? Have you checked for vacuum leaks?
Feb 15, 2010 at 2:44 PM
JACKK121
  • 9 POSTS
The Check engine lights has not came on. I haven't had the fuel pressure checked and I has a diagnostic test done which reveal nothing.
Feb 15, 2010 at 9:57 PM
  • 110,244 POSTS
WIthout a check engine light, it becomes a guessing game. I would start with fuel pressure. IF you need directions, let me know.
Feb 16, 2010 at 4:46 AM
JACKK121
  • 9 POSTS
I had my feul pressure checked and it okay 49.2 psi. Checked vacuum leaks and located nothing. I don't know where to go from here. My truck is running prefectly other then the Flucation with the RPM.
As I stated it I hit a bump the RPM will shot up and then return to normal. Driving on thehighway it shot up and return to normal just to shot up again. Again I lose no engine power.
I have no problem with my transmission and I am not sure this would casue the RPM to shot up.
Therefore, do you have any other suggestion?
Again, the check engine light is not on and have not come on.
Thanks, Dennis
Feb 17, 2010 at 9:42 AM
  • 110,244 POSTS
DennisL
Have you checked the connection to the throttle position sensor?
Feb 24, 2010 at 2:42 PM
JACKK121
  • 9 POSTS
I have not and will check the throttle position sensor connections today. I'll let you know once I complete checking the sensor connections.
Dennis
Feb 24, 2010 at 9:53 PM
  • 110,244 POSTS
Any luck, Dennis?
Feb 26, 2010 at 4:10 PM
JACKK121
  • 9 POSTS
I had the connection to the throttle position sensor check and everything okay there. Still no check engine light and I am getting ready to have Purge control solenoid check out. I'll let you know the outcome.
Feb 27, 2010 at 11:43 PM
  • 110,244 POSTS
I look forward to hearing what you find.
Feb 28, 2010 at 6:12 AM
