Hi:
It's done with the ignition key. At no point will you start the engine. With the key off, cycle it three times from off to the run position. On the 3rd time, leave it in the run position. All codes will be 2 digits. The light will flash one number then a slight pause then start the next number of the double digit number. Keep track of the blinks.
Jan 24, 2009 at 2:42 PM
