2002 Dodge Grand Caravan Brake Rubbing Noise
THE PROFESSOR
I have changed brakes in my 2002 dodge grand caravan 3.3 71200 miles on and when i brake there is a rubbing noise which appears to be from coming from the front i have had it checked from many people and the dealer but no solutions
Aug 25, 2007 at 3:55 PM
  • 75,988 POSTS
[quote:51dbc144c6="THE PROFESSOR"]I have changed brakes in my 2002 dodge grand caravan 3.3 71200 miles on and when i brake there is a rubbing noise which appears to be from coming from the front i have had it checked from many people and the dealer but no solutions[/quote:51dbc144c6]
Let it work in-not it open it up again and inspect the caliper piston could be binding or the seal to it is not retracting the piston that's the job of the seal is to pull it back when the rotor start slapping on it.
Or you have a brake hose acting like a check valve preventing the fluid to go back to the master cyl.
Aug 25, 2007 at 6:58 PM
Suggested Repair
Inspect the front caliper pistons for binding and seals that fail to retract the pistons. Also check the brake hoses for a check-valve effect that traps pressure and keeps fluid from returning to the master cylinder.
Conversation Summary
The owner of a 2002 Dodge Grand Caravan reports a front rubbing noise when braking after replacing the brakes. Several people and the dealer found no cause. The expert suggests a binding caliper piston or a seal that is not retracting the piston, or a brake hose trapping fluid so it cannot return to the master cylinder.
