ABS light
VTWIN800
2003 Dodge Grand Caravan 125000 mi 3.3 brakes are repaired how do you reset the ABS light so it is not on all the time...thank you.
****assuming the ABS system is repaired, how do you reset the light on the dash, or will it only go off when the repair is made, i thought the light stayed on until it was either cleared by a scanner or the battery disconected???****
Oct 15, 2007 at 9:55 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b9a05a0946="vtwin800"]2003 Dodge Grand Caravan 125000 mi 3.3 brakes are repaired how do you reset the ABS light so it is not on all the time...thank you.[/quote:b9a05a0946]
IT’S THE ABS SYSTEM
Fixing the brakes will not fix the ABS system problems
You need to have the system scanned for codes.
Each tire has a speed sensor on it that’s report to the BCM
And other components too.
Easy way to pin it have the system scanned
Good luck
Oct 15, 2007 at 10:15 AM
SERVICE WRITER
  • 9,123 POSTS
Your making a false association. The ABS is a system that is separate from the mechanical braking system you just worked on. Anti-Lock Brake (ABS) activates when the car is going into a skid. The wheels speed sensors send a signal to the ABS module. When the module doesn't receive a signal, because one wheel is moving a a different revolution than the others, it activates, causing a pulsing of the fluid to help maintain control during the skid.
You need to start by pulling codes from the ABS module.
Oct 15, 2007 at 10:16 AM
