2005 Dodge Caravan abs light on
130,000 MILES • 6 CYL • FWD • AUTOMATIC
ADIRONDACKER66
The abs light came on in our 2005 Dodge Grand Caravan. The shop said it was the abs pump motor and needs replaced. Another mechanic scanned it and said it didn't show up. When called about the part he was told that the wasn't a motor, but, an actuator. I would like to know which part is there, if not both, and which is more likely the problem. Also, it seems very hard to find those parts when searching online.
Sep 9, 2009 at 1:53 AM
CARADIODOC
  • 34,415 POSTS
These typically are not do-it-yourself parts and may have to come directly from the dealer. In a few years they will show up in the aftermarket world. The dealer is the best equipped place to service this problem, and not necessarily the most expensive. They have the factory training and know what to look for without wasting a lot of your money on diagnostic time.
caradiodoc
Sep 10, 2009 at 7:37 PM
ADIRONDACKER66
>>>caradiodoc Posted: Thu Sep 10, 2009 11:37 pm
caradiodoc <<<
I am not looking to do it myself. I just want to know which is correct. The abs pump motor or the abs actuator?
Oct 13, 2009 at 5:43 AM
CARADIODOC
  • 34,415 POSTS
I assumed you were trying to fix this yourself based on the type of questions you were asking and the type of web site you posted to. You don't have to be concerned about which part will fix the problem. That's up to the mechanic to properly diagnose the vehicle. If diagnosed incorrectly, a reputable mechanic will remove unneeded parts and not charge you for them. They will only charge you for the parts needed to solve the problem and possible other parts that will enhance the reliability of the repair.
"Also, it seems very hard to find those parts when searching online."
This is the comment that suggested you wanted to fix it yourself. I suspect you're not finding these parts online for the simple reason they aren't typically customer-replaceable parts. Repair shops generally don't buy parts online so the internet-based sellers would have very little market for parts like these. They're more interested in common consumer-replaceable items that have a larger demand.
The dealership has test equipment designed for their specific vehicles that should help them determine very quickly which part is defective. There is a pressure gauge that can be inserted in the line between the pump and hydraulic controller. A valve is closed, then you watch the pressure gauge. If pressure rises to 2200 psi or higher, the pump is capable of building pressure. If the pressure drops off when the valve is opened, there is leakage in the hydraulic assembly. If pressure can not be built up high enough, it's not necessarily the pump. It could be a plugged filter or a defective high pressure cutout switch.
I haven't replaced many ABS hydraulic parts so I don't know what the reliability of them is. GM trucks are famous for shorted computer modules that cause the pump to run continuously and burn out, but I haven't heard of that on Chrysler or products.
caradiodoc
Oct 13, 2009 at 9:29 AM
