To check the wheel bearings, have the vehicle up on a lift where the wheels are free, touch lightly on the spring as you rotate the tire, you will be able to feel the vibration throught the spring if the wheel bearing is going.
SPONSORED LINKS
Monday, May 7th, 2007 AT 8:05 PM
