97 dodge caravan 118000 miles 3.6 engine
Yesterday morning I started my van and noticed the odometer and transmission position did not illuminate.
Also noticed the speedometer and Tachometer were not moving. The ABS and check engine lights were on. Looked at fuses and relays wiggled with no difference. Drove the van for about 10 miles, then let it sit for a couple of hours. Before starting it again, wiggled the ABS fuse. When engine started everthing was back to normal. Do not know if I fixed anything or the problem went away. Drove 200 miles home with no noticable problems. Engine code lights are 12, and 66 and 55 at the end. Any idea of what if happening?
Thanks
Thanks
Jun 11, 2007 at 6:09 AM
