signal light -Dodge Caravan 2000
SOME_BUDDY56
Everytime I turn my signal light to the left,the inside indicator light flashes rapidly and I found out that the left signal light in front has no light and is not flashing. Is the fuse the problem?,if it is, how do I know which fuse belongs to the left signal light. Or is it only the light bulb that I need to replace? Please help.
May 5, 2007 at 6:19 AM
MIKE H R
  • 3,094 POSTS
there is one fuse for the signal lights, if the right works and the left front does not, check the socket and the bulb in the left front signal, also check the ground, when a bulb goes out on one side the flasher will go faster, even on the interior signal indicator
May 5, 2007 at 1:16 PM
