1993 Dodge Caravan Ticking Noise
BLAIRCOCOAMOO
I have a 1993 Dodge Caravan with 886000 miles it is constantly ticking. It usually does this when the oil is low however I had the oil changed just two weeks ago and the dip stick says the level is fine. My oil light also comes on when I turn sharply. What's going on?
Mar 14, 2006 at 1:10 AM
JDL
  • 16,098 POSTS
Sorry for the late reply.
It sounds like your about ready for an engine overhaul? You may be able to use an analog pressure gage in place of the oil pressure sending unit, to check oil pressure. For 3.3L engine, 5psi at idle, 30--80 psi at 3000 rpms.
You can try locating the tick, if you don't already know? You can use a long metal rod of some kind, place the end on the valve/cam cover, the other end, I place on that bone back of ear, it helps magnify the sound for me. If nothing there, try the same thing on the oil pan. If the ticking is coming from oil pan, pull oil pan see if any metal in the pan?
I realize this is an old post. In the future, hope you don't have any vehicle issues, but, if you do, keep the site in mind. They are always working to improve the site and it's free to ask a question.
Have a good day.
Jun 16, 2015 at 12:43 AM
Suggested Repair
Check oil pressure with an analog gauge in place of the sending unit (about 5 psi at idle and 30-80 psi at 3000 rpm on a 3.3L). Locate the tick with a long metal rod on the valve cover and oil pan. If the noise is from the oil pan, remove the pan and look for metal. At this mileage an engine overhaul may be needed.
Conversation Summary
The owner of a 1993 Dodge Caravan with very high mileage reports constant ticking even though the oil was recently changed and the level is fine. The oil light also comes on during sharp turns. The expert suggests verifying oil pressure with a mechanical gauge, locating the tick at the valve cover or oil pan, and inspecting the pan for metal if the noise is there, noting an overhaul may be due.
