2003 Dodge Caravan Ticking Noise at acceleration
71,000 MILES • 6 CYL • FWD • AUTOMATIC
THESTROUDFAMILY123
  • 9 POSTS
Whenever I press on the gas my engine makes a ticking noise. Probably not connected but it started doing it right after I had the transmission rebuilt.
Jul 29, 2010 at 4:09 PM
  • 110,248 POSTS
I think it is related to the work that was done. It sounds like an exhaust leak and they would have removed it. Take it back and have them check it.
Let me know what you find.
Jul 29, 2010 at 5:21 PM
THESTROUDFAMILY123
  • 9 POSTS
[quote:9986a9c4e1="Jacobandnickolas"]I think it is related to the work that was done. It sounds like an exhaust leak and they would have removed it. Take it back and have them check it.
Joe[/quote:9986a9c4e1]
I took it back to the shop and they said the exhaust was fine what else could it be
Aug 3, 2010 at 5:23 AM
  • 110,248 POSTS
Does the noise change with engine speed or vehicle speed?
Aug 3, 2010 at 5:02 PM
THESTROUDFAMILY123
  • 9 POSTS
[quote:253bf2fd03="Jacobandnickolas"]Does the noise change with engine speed or vehicle speed?[/quote:253bf2fd03]
The noise is only there when I press the gas and it goes away when I let off the gas. It does not change in noise level at all
Aug 4, 2010 at 4:08 AM
  • 110,248 POSTS
The only thing I can say without being there, is check to make sure all motor mounts and trans mounts are tight.
I need to explaine something. The reason I first said exhaust is because if there is a slight leak, it will make a ticking noise. Most people don't recognize it as an exhaust leak.
Aug 4, 2010 at 12:37 PM
THESTROUDFAMILY123
  • 9 POSTS
[quote:8f9719cbf3="Jacobandnickolas"]The only thing I can say without being there, is check to make sure all motor mounts and trans mounts are tight.
I need to explaine something. The reason I first said exhaust is because if there is a slight leak, it will make a ticking noise. Most people don't recognize it as an exhaust leak.[/quote:8f9719cbf3]
No problem. I am totally lost. I took it back to the transmission shop twice and they said everything looks good so I don't know what else it could be. GRRRRRRRRRRRRRR :)
Aug 4, 2010 at 3:07 PM
  • 110,248 POSTS
If I was there, I would help you find it. Since it started after they did their work, it has to be related to something they did. You may want to have another tech listen to it and get their opinion. If they can hear it, they may know exactly what it is and know if it is related to the trans replacement. I will note that Chrysler transmissions do make a clicking when first shifted into gear, but it only last a couple seconds.
Let me know what you find. I'm really anxious to know what it is.
Aug 5, 2010 at 3:09 PM
THESTROUDFAMILY123
  • 9 POSTS
[quote:a984bbd1ac="Jacobandnickolas"]If I was there, I would help you find it. Since it started after they did their work, it has to be related to something they did. You may want to have another tech listen to it and get their opinion. If they can hear it, they may know exactly what it is and know if it is related to the trans replacement. I will note that Chrysler transmissions do make a clicking when first shifted into gear, but it only last a couple seconds.
Joe[/quote:a984bbd1ac]
I will let you know what i find. If not you can always come and find out what it is HE HE
Aug 5, 2010 at 3:27 PM
  • 110,248 POSTS
I wish I could.
Aug 5, 2010 at 5:58 PM
THESTROUDFAMILY123
  • 9 POSTS
[quote:a35b5c3c0d="Jacobandnickolas"]I wish I could.[/quote:a35b5c3c0d]
I am gonna go to a shop tomorrow and have someone look at it and I will let you know what they say
Aug 5, 2010 at 7:24 PM
  • 110,248 POSTS
Let me know what you find. And, if you live near Pittsburgh, let me know. I'll try to help.
Aug 6, 2010 at 4:15 PM
THESTROUDFAMILY123
  • 9 POSTS
[quote:ec256cee9f="Jacobandnickolas"]Let me know what you find. And, if you live near Pittsburgh, let me know. I'll try to help.
Joe[/quote:ec256cee9f]
I live in Idaho quite a ways to go HE HE
Aug 6, 2010 at 5:39 PM
  • 110,248 POSTS
Yes, that would be quite a trip. Regardless, let me know what you find or if you have other questions.
PS: Isn't Idaho where they have all the tornados?
Aug 6, 2010 at 6:25 PM
THESTROUDFAMILY123
  • 9 POSTS
[quote:43c26189bb="Jacobandnickolas"]Yes, that would be quite a trip. Regardless, let me know what you find or if you have other questions.
PS: Isn't Idaho where they have all the tornados?[/quote:43c26189bb]
No tornados we are known for potatoes Northwest
Aug 6, 2010 at 7:10 PM
  • 110,248 POSTS
I just ate a bag of chips. Thanks. (LOL). I bet it's beautiful there.
Let me know what you find with the vehicle.
Aug 7, 2010 at 3:53 PM
THESTROUDFAMILY123
  • 9 POSTS
[quote:23fecdfc3f="Jacobandnickolas"]I just ate a bag of chips. Thanks. (LOL). I bet it's beautiful there.
Joe[/quote:23fecdfc3f]
Ha Ha It is beautiful here we are at the only confluence in Idaho right next to Washington we have hills all around us
Aug 8, 2010 at 4:20 PM
