I have a Dodge Caravan 1996, 145,000, 3.3 litres.
The fan comes on when you start the engine and donot turn off. The temperature gauge stays at C.
I had a computer test run and came up with the following problems.
1) Camshaft Sensor Circuit
2) Rad Fan Control Relay Circuit
3) ECT Circuit Volt Low
4) Battery Temp. Sensor Volt too Low.
I have change a part which is located on the drivers side in front by the radiator but that did not help.
What should I do?
What should I do?
May 13, 2007 at 7:16 AM
