1998 Dodge Caravan Fans Won't Shut Off
DALLEN
I have a 1998 Dogge Caravan and the cooling fans will not shut off.
Mar 4, 2007 at 7:11 AM
  • 75,988 POSTS
[quote:e5b964b972="dallen@gvisd.org"]I have a 1998 Dogge Caravan and the cooling fans will not shut off.[/quote:e5b964b972]
Check the temperature switch for the fans
Mar 4, 2007 at 1:09 PM
BHUGG
  • 157 POSTS
Check for a defective fan motor relay. I don't know the Caravan, but it is likely under the hood in a bopx with fuses and relays. If you find the relay, pull it out and try to trade it with any other like relays in the box. If it works fine with another relay, replace the relay.
Good luck.
Let the forum know what happens. We like feedback.
If we help, vote for those who deserve it.
Mar 4, 2007 at 3:08 PM
MIKE H R
  • 3,094 POSTS
the relay sounds like it is stuck. if you dont have a diagram of the relays, check under the hood and the ones you dont know about, take one out at a time with the car running. when the fans go off then you have found the relay. interchange it with one of the other relays as long as they are labled the same number. do you do any towing with the car? I can tell you what i did some time ago with the reference to cooling fans on another kind of car.
let me know what you find!!!
Mar 6, 2007 at 6:44 AM
Suggested Repair
Check the cooling fan temperature switch and the fan motor relay. Locate the relay in the under-hood fuse and relay box, swap it with an identical relay, and replace it if the fans then shut off.
Conversation Summary
The owner of a 1998 Dodge Caravan reports that the cooling fans will not shut off. Experts suggest checking the fan temperature switch and a stuck fan relay, including swapping the relay with a matching one in the under-hood box.
