1993 Dodge Caravan Hood Release Cable Fix
BYB7652
What is the easiest way to remove and replace the hood release cable?
93 Dodge Caravan
May 25, 2007 at 7:04 AM
E40WATER12
  • 522 POSTS
For starters you have to pop the hood undo the 4 or 5 bolts that hold the hinge down undo the cable clip, Then undo the clip inside the kick panel near the inside of the car, undo the plastic clips at hole the cable into place, Then pull the cable through the car.
then install the same way.
May 27, 2007 at 5:11 PM
Suggested Repair
Open the hood, remove the four or five hinge bolts, and release the cable clip. Inside the vehicle, release the clip at the kick panel and the plastic clips holding the cable, then pull the cable through. Install the new cable in reverse order.
Conversation Summary
The owner of a 1993 Dodge Caravan asked for the easiest way to remove and replace the hood release cable. The expert advised opening the hood, unbolting the hinge, releasing the cable clips at the latch and kick panel, pulling the cable through the vehicle, and installing the replacement the same way.
