I have a 2000 Dodge Grand Caravan with a 3.3L engine. It has 175K miles on it.
While driving, the engine RPM suddenly increased and the service engine light went on. I pulled into a parking lot and turned the engine off. It restarted easily but when I shifted to drive it stalled. This happened twice. I then started the engine and shifted to reverse and the engine stayed running. I shifted to drive and it was still ok. I left the car in the parking lot over night. When I came back the next day the engine started right up and it drove normally. the service engine light was still on. I checked the codes and the only code that came up is 55. Since there was no information I pulled the battery cable to clear the light. I have driven the car short distances and it seems fine. The service engine light is still off. Any idea on what I should replace? The fuel pump was replaced about 40K miles ago.
Dec 7, 2006 at 6:54 AM
