2003 Dodge Caravan P0456 EVAP Leak
Post your codes, and we'll see what we can do.
If you replaced the gas cap, and put the tank at 3/4 full. Then drive normally for a few days, that MAY solve it. This isn't a problem that is going to need immediate attention.
What will be tough for you to go after it yourself it may be the tools of the trade, such as possibly a smoke machine ( a machine that injects smoke into the evap system and exposes leaks, or if there is a faulty computer ( which may come down to a guess) or a scanner that can operate the system. NOt to mention the knowlege of the system.
I'll help where I can, as you like. Ask away and I'll try :)
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Suggested Repair
Replace the gas cap, fill the tank to about 3/4, and drive normally for a few days. If P0456 returns, have an independent shop smoke-test the EVAP system; a PCM-related TSB may also apply. This is not urgent.
Conversation Summary
The owner of a 2003 Dodge Caravan SE 3.3L wanted to read a check engine light without paying shop diagnostic rates. AutoZone retrieved code P0456 after an initial misread of P0465. The expert identified a medium evaporative-system leak, often caused by a loose or bad gas cap, and suggested trying a new cap with the tank about 3/4 full. Further diagnosis may require a smoke machine or scanner, and a TSB mentions PCM replacement. An independent shop was recommended rather than guessing. Another user noted that a Dodge key-on cycle can display codes.
