1994 Dodge Caravan Code 21 Hesitation
94 DODGE
  • 6 POSTS
I believe the 12 means a code is about to be shown. I have a 94 Dodge Caravan 3.3L I believe its the sports edition, I have several questions;
1.) What does check engine code "21" mean?
2.) Is it expensive to repair this issue? (Im a student and have a very tight budget.)
- Here is what I have witnessed... whenever I drive on the highway my engine hesitates and does a cardiac arrest motion and starts jolting.
- As soon as I get off the highway it loses power and I have trouble gaining full power again.
3.) Does this problem have anything to do with my fuel supply? My gas gauge likes fluctuating on its own one min im full next min im half tank next min im empty. I avoid this issue by filling up 10$ everyday when I can. Can you suggest anything that can help? Someone suggested it was my floating device in my gas tank but I think its bigger then that. I tend to smell gas like its leeking or something but i never see anything. I have a feeling its my fuel injection because it might be related to my check engine code "21" problem PLEASE any ADVICE WILL BE GREATLY APPRECIATED! Please email me aswell if you can Im not posting my email but I believe adminstrators of this website might have it.
Oct 29, 2007 at 12:17 PM
MERLIN2021
  • 17,250 POSTS
12 is battery dissconnected within last 50 drive cycles, or power to the module was lost...21 is the 02 sensor, if the ground or power wire to the module is intermittently bieng lost you can get these strange symtoms, try wiggling the wires and pushing the connector on tighter. The gas smell, check the filler tube for rust holes!
Oct 30, 2007 at 10:17 AM
Suggested Repair
Code 12 indicates the battery was disconnected or module power was lost within the last 50 drive cycles; code 21 points to the oxygen sensor. Check for intermittent power or ground loss by wiggling the related wires and firmly reseating the connector. For the gas smell, inspect the filler tube for rust holes.
Conversation Summary
The owner of a 1994 Dodge Caravan 3.3L reported check-engine codes 12 and 21, highway hesitation and jolting, loss of power after exiting the highway, a fluctuating fuel gauge, and a gas smell without a visible leak. The expert explained that code 12 means battery or module power was lost recently and code 21 relates to the oxygen sensor. Intermittent power or ground to the module can cause the drivability symptoms, so the wiring should be wiggled and the connector pushed on tighter. The gas smell should be checked by inspecting the filler tube for rust holes.
