2000 Dodge Grand Caravan Brake Lights Out
96SILVIA
  • 11 POSTS
I have a 2000 Dodge Grand Caravan with a 3.0 liter engine with about 116,000 miles.
My problem is that both the left and right break lights don't come on when the brakes are pushed. Both brake lights went out at the same time. a couple of days ago. I checked the fuse and replaced it. still nothing. the regular lights work the reverse lights work I pulled the bulb out and can't see a break in the filiment. What else could it be?
Jul 3, 2007 at 3:04 AM
LEGITIMATE007
  • 5,121 POSTS
behind your break pedal , there is a breaking switch which is pressed when you press your break pedal. Make sure that it is plugged in; it may have been disconected somehow.
Jul 24, 2007 at 3:45 AM
Suggested Repair
Inspect the brake light switch behind the brake pedal and confirm it is plugged in and operating, since both brake lights failed together while the other rear lights still work.
Conversation Summary
The owner of a 2000 Dodge Grand Caravan says both brake lights stopped working at the same time. The fuse was replaced, the bulbs appear intact, and the regular and reverse lights still work. The expert advises checking that the brake switch behind the brake pedal is plugged in.
