1993 Dodge Caravan Brake Bleeding
BYB7652
How do you bleed the brakes on a 93 Dodge Caravan? Any special tools needed?
May 24, 2007 at 3:47 AM
BOOTDOG
  • 665 POSTS
yep, a wrench, brake fluid and a foot. lol get a wrench to fit the bleeder screws, have someone inside the vehicle to pump the brake pedal 3 to 4 times between each session. after the 3 or 4 times have the helper hold the pedal down. the you break the screw loose until fluid stops coming out. tighten the screw then have the helper pump it again. do this on each wheel till all air is out. the sequence to use is, right rear, left rear, right front and left front. check the fluid level time to time to make sure the master cylinder doesn't run dry. good luck :wink:
Feb 21, 2021 at 9:05 AM
Suggested Repair
Bleed the brakes with a wrench that fits the bleeder screws, fresh brake fluid, and a helper. Pump the pedal 3 to 4 times, hold it down, open the bleeder until fluid stops, then close it and repeat. Work right rear, left rear, right front, then left front, and keep the master cylinder from running dry.
Conversation Summary
The owner asked how to bleed the brakes on a 1993 Dodge Caravan and whether special tools are needed. The expert said a fitting wrench, brake fluid, and a helper are enough: pump the pedal several times, hold it, open each bleeder until fluid stops, then tighten and repeat. Bleed right rear, left rear, right front, then left front, checking the fluid level so the master cylinder does not run dry.
