antifreeze drip
DSTUDENT
98 dodge grand caravan...for awhile i have a small drip coming from under the passenger side of the vehicle and yesterday as I was leaving work there was a large puddle under the passenger side and it was the antifreeze from the resevoir, i filled the resevoir and the radiator in order to get home..it did not do any dripping after that, but this morning i did notice a small wet spot under the same area, I drove it to work this morning, it has sat for about 4 hrs and still nothing dripping...please help
Sep 20, 2006 at 3:46 AM
BUBBA_KOSKI
  • 129 POSTS
check the cap, make sure shes on tight, and the water pump if your water pump had a weeping hole, thats were she may be leaking, fix her now b4 big problems, also check the upper and lower radiator hoses
Sep 27, 2006 at 4:11 PM
