1993 Dodge Caravan Won't Start Click
DODGEMAN
Hi i have a dodge caravan that wont start i took the starter off and had it tested it works fine it just clicks i dont think its the battery because the lights work and the power windows work the blinkers work but the window wipers dont work its a 6 cyl ,3.3L please help
Jun 6, 2006 at 12:44 PM
SYNCRAIT
  • 235 POSTS
im going to bet it is the battery although the rest of the stuff does work..... it just isnt enough amperage to get the starter to turn over..... try jump starting it and let it run for a while... also at night turn on your headlights, blower, radio, and see if either your radio cuts out or your headlights dim substantially
Jun 6, 2006 at 12:52 PM
DODGEMAN
i have already tried to jump it and it just it doesnt start just clicks could it be wiring or the alternator the clicking clicks on top of the motor not the bottom where the starter is
Jun 6, 2006 at 1:10 PM
  • 55,694 POSTS
This sounds like you have bad starter relay her is the location so you can swap it out. Check out the images (below). Please let us know what happens.
Oct 28, 2024 at 10:39 AM
Suggested Repair
Replace the starter relay. The starter tested good and a jump start did not help, and the click is coming from the top of the engine rather than the starter.
Conversation Summary
A 1993 Dodge Caravan 3.3L will not start and only clicks. The starter tested good, lights and power windows work, and a jump start did not help. One reply suggested low battery amperage, but after the owner noted the click is on top of the engine, the expert diagnosed a bad starter relay and recommended swapping it.
