1993 Plymouth Voyager Hard Brakes
RICHIE RICH
We have a 93 Caravan, today while driving the ABS,and brake light came on. I continued to drive after checking to see that the emergency brake was released. After stopping the vehicle, and re-starting it to drive I noticed I could not apply the brakes. Only with a lot of force, could the vehicle hardly stop. What could be going on? Thanks! IT is a 1993 Dodge Caravan extended 3.3L, 160,00 km's
Mar 19, 2007 at 5:35 PM
SERVICE WRITER
  • 9,123 POSTS
You need to have the anti-lock brake system looked at. There will be codes stored in the computer to help diagnose this condition. The abs module is making false decisions.
Mar 19, 2007 at 10:13 PM
RICHIE RICH
Thanks for your reply on previous question. We decided to replace the ABS pump, our question as a precaution is, with no other hydraulic line disconnected, any bleeding of air from the system required? Thanks. ( actually it is a Voyager, not Caravan)3.3L 160,000 km
Mar 20, 2007 at 5:36 PM
SERVICE WRITER
  • 9,123 POSTS
No special bleeding, except go from left rear, right rear, Left front , right front when bleeding.
Mar 21, 2007 at 11:08 AM
Suggested Repair
Have the ABS system diagnosed using stored codes, since the ABS module may be making false decisions. After replacing the ABS pump with no other hydraulic lines disconnected, no special bleeding is required; bleed in order from left rear, right rear, left front, then right front.
Conversation Summary
A 1993 Voyager showed ABS and brake lights, then the brakes became very hard to apply. The expert advised diagnosing the ABS system with stored codes and said the ABS module may be making false decisions. After the owner replaced the ABS pump, the expert said no special bleeding was needed beyond the left-rear, right-rear, left-front, right-front sequence.
