2007 Dodge Caravan Instrument Cluster
2007 DODGE CARAVAN
YOUNGKU
Electrical problem
2007 Dodge Caravan 6 cyl Front Wheel Drive Automatic 50k miles
The left lower portion of my speedometer lighting is dim, almost like there are some failed light bulbs in that area. However, after driving for a while, the lights came back on to full strength. This just started happening and occurs now all the time.
My questions are:
Could this be related to a turn signal that had blinked and clicked very rapidly just a week before--this has not happened since (usually a rapidly blinking turn signal indicates a failed turn signal)?
Is this a failing bulb(s),
Could the voltage regulator be failing/faulty?
Could this be due to a battery that had died previously and was jumped (the car's original battery, probably needs to be replaced)
Thanks,
Kurt Young
Dec 29, 2009 at 4:52 AM
CH112063
  • 1,320 POSTS
I would have to say yes to all. Its a cluster module and there are a couple other modules and computers involved. My advice is to test or replace the module using a good scanner which can reset or help locate the problem. Sorry, you can try disassembling the trim, removing it, checking and re-connecting.
Dec 29, 2009 at 10:53 AM
