The pump pulley must come off by taking off the pulley from the drive sprocket of the water pump, then you have access to the water pump then those come off by turning the loosened pulley to access these hold down bolts. Its a tight fit. the belts and plastic splash guard come off first. I don't think your doing it wrong, it is a pain to get a larger hand in there. It takes all kinds of wrench or socket turning. Sorry your having trouble, I wish I could go there and do it for you. OK the pulley is removed to access the pump bolts. It goes on last.
Be careful, ok. It was a hoist job so try to get it done slow and don't let it get you too aggravated. Its more important to get another ride, and do it a little each day. I know its hard but I'll be contemplating and hoping you get it, if that helps. I'm glad to help you. ok
Nov 30, 2009 at 11:40 PM
