Air Conditioning problem
2004 Dodge Caravan 6 cyl Front Wheel Drive
The fan to blow hot or clod air is running but very little air is moving out of the vents. Its like a vent somewhere is stuck.
Saturday, June 26th, 2010 AT 10:27 PM
MECHANIC
Have you checked for vacuum leaks? The vent doors that direct air flow are actuated by engine vacuum. Check under the dash and the hood. If you are lucky, with the engine running, you may hear a hissing noise from where the leak is located.
